Results 1 to 11 of 11
Thread: LS6 intake
09-24-2009, 09:20 AM #1
LS6 intake
i have heard that some f-bodies came stock with the ls6 intake manifold and i was wondering how i could tell if i had it
09-24-2009, 09:26 AM #2
01-02 camaro's got the LS6 intake. It has no EGR provision behind the throttle body, that's the first sign.
The part number is located on the driver side rail about in the middle of the engine, right between #3 and #5 coil packs. I believe the number is 12561184 for the F-body,,,there are other numbers that apply to the vettes and cadilacs.
09-24-2009, 09:46 AM #3
thsnks man thats what i thought but just wanted to be sure
09-24-2009, 10:29 AM #4
2001-2002 have the ls6 intake and around 20% (i belive) 02 engines are the ls6 blocks
09-24-2009, 10:50 AM #5
i herd they used the ls6 blocks because they ran out?
09-24-2009, 09:21 PM #6
09-25-2009, 12:55 PM #7
how can you tell if it has a LS6 engine?
09-25-2009, 01:47 PM #8
09-26-2009, 08:07 PM #9
09-27-2009, 09:31 AM #10
what will it have that will let me know it is a LS6?
will it have LS6 cast in the block?
09-27-2009, 10:50 AM #11
- Mar 2009
- pompano beach florida
- 2002 Camaro Z/28 Pewter
Technically its just the block not the whole ls6 engine. There should be a number on the block on the rear of the ds head not sure what it is exactly but I believe it ends in 1168? Also if you look on the block by the front of the heads where the coolant lines are there will be a bullseye if its an ls1 or it will just be blank if its an ls6.
Dan
BBK SSI Intake, vs Holley Intake, vs LS6 intake, vs PP 96mm
By Lunatikgixxer in forum External EngineReplies: 26Last Post: 02-28-2017, 10:39 AM -
Question: HOW TO: Swap stock intake with LS6 intake
By thechad125 in forum General HelpReplies: 18Last Post: 02-26-2013, 03:17 AM -
LS6 intake manifold and 227 Intake runners
By IT_SS in forum Internal EngineReplies: 4Last Post: 07-07-2009, 02:11 PM -
Single Plane Intake VS Stock PP Intake
By xzaero0 in forum Forced InductionReplies: 1Last Post: 11-27-2007, 07:00 PM -
Difference in Stock Ram Air intake and other aftermarket intake
By WS6-cobra killer in forum Firebird / WS6Replies: 5Last Post: 01-15-2007, 06:47 AM
