Results 1 to 20 of 47
Thread: ??? LS1 Heads vs LS6 Heads ???
02-21-2009, 03:50 AM #1
- Oct 2007
- Macomb, Michigan
Black on Black- 2001 ~ T/A ~ WS6 ~ M6
I have an opportunity to pick up a set of stock LS6 heads.
Will a set of LS6 (243) heads bolt directly on to my 2001 LS1 engine without any modifications?
Is so, what are the pros and cons from a performance standpoint?
Thanks.
(Oops...should be list under "External Engine".)Last edited by midi_2001; 02-21-2009 at 03:55 AM. Reason: Wrong help section...
02-21-2009, 04:02 AM #2
- Oct 2006
- St. Clair Shores. Michigan
Direct bolt in and a nice powergain.
I would add headers and a cam at the same time.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
02-21-2009, 04:27 AM #3
- Oct 2007
- Macomb, Michigan
I've already got the exhaust and I was planning on just a cam swap and not messing with the heads when I ran across these.
My cam considerations 'were' either:
Vector Motorsports: 228/232 .588/.574 112LSA
or
Thunder Racing: 230/224 .575/.563 111LSA
But I believe these heads would open the door to other options.
02-21-2009, 08:18 AM #4
02-21-2009, 09:42 AM #5
- Oct 2007
- Macomb, Michigan
Well, I bought them and just picked them up. A guy locally had them on Craigs List as BO. Got them for $350. They're definitely 243's with the yellow springs. He said they only have 3k miles on them and they look like it as well.
02-21-2009, 09:53 AM #6
Hmmm I might have to try and find me some lol
02-21-2009, 10:06 AM #7
- Oct 2007
- Macomb, Michigan
02-21-2009, 10:50 AM #8
02-21-2009, 11:15 AM #9
- Apr 2007
- Forest Lake, MN
maroon- 2000 Z28
A cam and some work on the LS6 heads (port and mill) can give you a 80+ rwhp gain.
02-21-2009, 11:21 AM #10
02-22-2009, 04:08 PM #11
- Apr 2007
- Forest Lake, MN
maroon- 2000 Z28
I've seen 500 on up to 2k. Depends on who you send them to and how much port work you want. Tony Mamo's of AFR is probably the best known. It'll cost a little money for him to do it. TSP does it also.
02-23-2009, 09:26 PM #12
You hit jack pot just like me. I picked up LS6 heads too about 3 days ago. Looking at your pictures, you have the Triangles by the plugs which I do to, it means about 5 - 7 rwhp more over normal LS6 heads due to different casting process. Do a search on it and you'll get lots of info on them.
┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
02-25-2009, 02:59 PM #13
02-25-2009, 03:33 PM #14
350 for complete heads thats a deal. You could port the heads but that's extra money, if you want to keep cost down get an asa cam w/ a low lift so you can keep the springs and you should have over 400rwhp no problem. Or swap out springs and go big.
02-25-2009, 03:53 PM #15
- Oct 2007
- Macomb, Michigan
If my setup was, 2001 LS1 (WS6) M6 with, SLP lid, ported TB, stock LS6 intake, unported LS6 heads (243's pic'd above), Kooks 1-3/4" LT's, Kooks ORY, Magnaflow CB and 3.73 gears, what cam would produce the most HP and torque without overkill?
And again, with the same setup but porting the 243 heads?
(Changing the springs to accomodate the cam is not a problem.)
02-26-2009, 08:47 PM #16
Here's a secret: If you want the best heads for performance, make sure your heads have these small triangle marks below every spark plug hole. The marks are left by "chills" used during the casting process in GM's semi-permanent mold (SPM) tooling. Of the three casting facilities that make Gen III cylinder heads, two use SPM tooling, the other heads are sand-cast. The SPM tools produce heads with very smooth, consistent ports and chambers which consistently dyno at least 4 to 7 hp better than the sand-cast heads.
Thats from this website with pics
http://www.carcraft.com/techarticles...ads/index.html
02-27-2009, 03:14 AM #17
Just wanted to let you guys know I called Wegner Motorsports a few weeks ago, they will port and polish a set of ls6 heads with a valve job for $550
Mine are going there when I get some $$$
02-27-2009, 04:24 AM #18
02-27-2009, 04:27 AM #19
02-27-2009, 11:43 AM #20
I put LS6 H/C on my 99 Trans Am WS6. I also put pacesetter headers and the difference is unimaginable. I got a custom tune for TSP and my car idles perfect at about 900rpm and my gas mileage is still decent. 550km/tank highway
Late-Model GTO Heads and Cam - The Voice Inside Our Heads, P
By Ed Blown Vert in forum GTOReplies: 0Last Post: 03-16-2011, 09:30 AM -
By Ed Blown Vert in forum GTOReplies: 0Last Post: 02-04-2011, 02:00 PM -
AFR heads VS. Ported and beefed up stock heads.
By hutcher04 in forum Internal EngineReplies: 10Last Post: 03-14-2010, 08:27 AM -
New Heads or Port/Polish Stock Heads?
By Black02LS1 in forum Internal EngineReplies: 32Last Post: 06-22-2007, 11:29 PM
