Results 1 to 20 of 37
03-15-2010, 11:32 PM #1
Are these factory shocks/ strange feel
I'm trying to decide if the shocks have ever been replaced on my son's 01 Camaro. It has been doing some weird side-to-side shake (instead of the normal up-down expected response) when the rear would hit a dip and putting the 19" C6 wheels on has really amplified the strange feel. The tires were really worn that were on it so I didn't worry a lot about it until we got the other tires/wheels on this afternoon and test drove it. Now I'm hoping it's a bad shock, if not, what else could it be?
Here is the photo
03-15-2010, 11:36 PM #2
Yes DeCarbons are factory shocks.. You may have a bent rim.. Could be a bad tie rod or ball joint.. Can you tell if the shacking is comming from the front or back? Does it get worse under braking?
03-15-2010, 11:54 PM #3
There also could be a drive shaft balance issue..
03-15-2010, 11:59 PM #4
It's not a shaking/vibration, it's when you hit a dip in the road instead of the car dipping up-n-down as expected, it has a side-to-side feel almost like one shock is working and the other is not or ???? It did it before we installed these wheels/tires, it just seems more amplified now because these tires don't have sidewalls or tire lean to help absorb the feeling.
03-16-2010, 12:15 AM #5
It could be your shocks, DeCarbons where junk new imho. I'd jack it up and support the car and lock the steering wheel then try wiggling the front wheels @ 9 and 3 o'clock then 12 and 6. Then go to the rear and pull in and out on the wheels see if there's a lot of in and out play. CHeck the panhard bar for broken bolts and/or worn bushings. CHeck the sway bars and bushings for damage and/or heavy wear too. Then with the car on stands check to make sure all the bolts in the torque arm are there and tight.. Basicly go over everything suspention wise keeping an eye out for anything that doe'nt look right or seems to have heavy wear.
03-16-2010, 07:05 AM #6
- Jul 2008
- SoCal, SD
Brickyard 400 Trac Car#10- 35th Camaro SS/LE Vert
17" wheel & tire to a 19" wheel & tire also means more weight the stock shocks have to deal with could be why it's amplified the problem. Now you have to find out why. Follow Smittro's advice. How many mile on the car?
03-16-2010, 11:29 AM #7
Yes & yes, good advice and very true. The car has 123K on it and if those are the factory shocks they are WAY past their prime. I thought they might be but both the front and rears looked in great condition physically just a little road film or they would have looked new. I'm gonna go over it this weekend, put on some new shocks and put a wrench on every bolt I see.
NOW, what's a good shock
03-16-2010, 11:44 AM #8
Got a budget in mind ?
SLP Bilsteins $410, and If there within you budget Koni SA's $750 to $850Last edited by Blue28; 03-16-2010 at 11:59 AM.
03-16-2010, 12:09 PM #9
Or another set of standard shocks other than Decarbons. If you don't care for the expense of big name brands. I run KYB's not too pricey and work well with the lighter 3800 f-bodies..
03-16-2010, 12:37 PM #10
I was wondering about the KYB's, just need a good quality shock. Not really worried about how it might help the cornering. Thanks Blue, I had actually searched some previous posts and saw some of your suggestions after I asked for info.... Good stuff
03-16-2010, 12:57 PM #11
03-16-2010, 03:01 PM #12
I haven't read all the responses but it sounds like your panhard bar is loose. Sometimes the bolt hole ovals out on the passenger side.
03-16-2010, 10:30 PM #13
03-17-2010, 12:42 AM #14
03-17-2010, 05:47 AM #15
03-27-2010, 07:25 PM #16
Well, I replaced the rear shocks today and while I can tell it's better, the problem is still there. Are there bushings in the trailing arms(??) that might be worn maybe cause this type feeling. Or I was wondering if we might have a bad spring. I'm
03-28-2010, 05:45 AM #17
03-28-2010, 11:54 AM #18
03-28-2010, 05:21 PM #19
The bushings could be worn on it. That's about all I can think of off-hand.
When my car felt like how you are describing yours to feel (swaying back and forth) on the V6 Camaro at highway speeds I could physically move mine around a little even though the bolts were tight. When I loosened it I found that the bolt hole in the bracket was a little egg-shaped. I ended up welding 3 thick washers to the backside of the bracket and then bolted it back up. Problem solved.
03-28-2010, 06:08 PM #20
Which side did it egg-shape the hole on? I even tried moving the axle left an right while it was jacked up and didn't feel any play.
STRANGE,STRANGE Trans Ams
By fbodyNATION in forum Firebird / WS6Replies: 4Last Post: 08-27-2013, 03:29 PM -
what do you do when you feel down?
By pecha in forum Almost Anything GoesReplies: 63Last Post: 04-11-2010, 06:47 PM -
how will 3.73's feel
By jimmybling31 in forum DrivetrainReplies: 13Last Post: 05-03-2008, 03:41 PM -
Are factory shocks 50/50
By rickssz in forum Suspension and HandlingReplies: 1Last Post: 03-16-2007, 02:46 PM -
HAL vs Strange Front Shocks
By RED98WS6 in forum Suspension and HandlingReplies: 0Last Post: 10-09-2005, 10:32 AM
