02-10-2011, 11:22 AM #1
- May 2008
- New Brunswick
Extra Overdrive, Gear Splitter, Double OD ... Any Options
Does anyone know of a product like this? I'm could be happy enough with a 4 speed auto and the right rear gear for racing, but it leaves me with a loud, gas hog when it comes to highway cruising. Some kind of gear splitter, aftermarket overdrive unit, or the like would make a good add on...if I could find such a thing.
I know about the Gear Vendors unit, but its designed to be a lot more than just a simple extra overdrive, it can split ALL gears, handle over 1200hp, and its very expensive. I would be happy with something simpler and cheaper, if it exists.
02-10-2011, 11:35 AM #2
Gear vendors is it. They have been around since the 60's making these things if I remember right.
If you want a gear splitter, and an overdrive, they are the way to go. Not really all that expensive either when you think about it and consider what you are getting.
There are transmission out there twice the money that don't do what a Gear Vendor unit does.
02-10-2011, 11:39 AM #3
What could you possibly be running for a gear to create a gas hog along with an overdrive??
You can easily stick 3.73's or 4.10's in these things, and with a .70 overdrive they are still very comfortable on the highway.
Don't get me started on rear gears in an overdrive car,,,, You guys don't realize how good you have it.
Try 4.88's and no overdrive, I take these cars everywhere.
02-10-2011, 11:09 PM #4
here-here on the 4.88's, back in the 60's wife drove as DD 67 mustang /427/2x4/4.88 no OD, we at the time ran a service station selling reg gas @ 19.9 per gal ,premem @ 24.9 per gal. I do not rember our cost per gal, I was driving 90 miles a nite to machine school and we advadged 4 1/2 -5 mpg. hard to think about that kind of milage today
JohnnyLast edited by SS SLP2; 02-11-2011 at 06:55 AM.
Y2K SS (SLP #239)
Completly STOCK heads/bore/stroke/weight
& NOTHING else ---is stock
"NAW-NAW- just a Sunday goto meeting car, my best time is not in the 12's------- any more "
ps: I am not soliticing work as I am retired
>>>info on alignments
http://www.jgruggles.com
02-11-2011, 06:28 AM #5
02-11-2011, 08:54 AM #6
- May 2008
- New Brunswick
Ok Ok, so we do have it pretty good already compared to the old days without any overdrive. I imagine those 4.88s had you guys in the High 3xxx RPMs while cruising at 60? That would be rough.
I've just been running some #s and if I step the gears up a bit I could end up cruising at 2700 or so. Speed limits run a bit faster here, I generally cruise at 73mph without any risk of flashing lights in the rear view mirror.
2700 isn't too bad, but it does cut down the mileage somewhat and its well into the range where my exhaust goes from barely noticeable to loud as hell. Don't get me wrong, around town the radio is off and I love to hear the engine, but on long highway trips its a pain to not be able to hear a conversation with your passengers.
Taking the overdrive from 0.75 (4l80e or th400) to .55 would get those rpms down to the 2000 range where things are still relatively quiet.
02-11-2011, 09:03 AM #7
- Feb 2007
- San Diego, CA
67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
Splitter
By davidz28 in forum Appearance SectionReplies: 12Last Post: 12-01-2010, 09:05 PM -
Question: Lost 1st gear and Overdrive????
By joedude02 in forum Automatic TransmissionReplies: 5Last Post: 03-23-2010, 08:27 PM -
Double din Options
By JaycenK in forum Stereo and ElectronicsReplies: 21Last Post: 06-16-2009, 11:53 AM -
Splitter
By Sarge in forum GTOReplies: 41Last Post: 02-19-2009, 07:48 PM -
Someone Please Send Me Link To The Pic Of Double Pink And Double Stink
By 02cetransam in forum Almost Anything GoesReplies: 33Last Post: 09-25-2007, 06:22 PM
