Thread: header gaskit
08-01-2014, 06:20 AM #1
- Feb 2008
- jupiter fl.
white- 2000 trans am
header gaskit
I purchased a stock set of gm exhaust manifold gas kits like I was advised to for my lth install should I be putting them on dry or with some high temp rtv on both sides
08-01-2014, 06:50 AM #2
NO RTV.....if you had graphite gaskets you need to carefully remove all the residue. Do not use steel wire brush on the block or heads. Use a brass wire brush so that it will not scratch the aluminum surface of the block or heads.
08-01-2014, 12:39 PM #3
- Feb 2008
- jupiter fl.
thanks for the help,
also can I install and use my car with the new tune that frost did with some deletes before I actually install my lth,s and disconnect egr,rear o2's etc
08-01-2014, 06:31 PM #4
yes
08-02-2014, 05:27 PM #5
I agree - install them dry without any type of sealant. Stock gaskets are the way to go on our cars.
08-03-2014, 03:35 AM #6
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
I also agree with stock gaskets and new bolts. I got the GM replacements fairly cheap. When you get them on and torqued to spec start it and let it heat up then give each bolt another pound. Will help bolts from coming loose. Just don't burn your hands!
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
Post LT header install header issues
By ob02z28 in forum External EngineReplies: 20Last Post: 02-18-2010, 04:10 PM -
Header Help!!!
By chevyjunkie321 in forum External EngineReplies: 1Last Post: 10-03-2008, 09:34 AM -
!!!Header ?!!!
By Bender10 in forum External EngineReplies: 7Last Post: 12-29-2007, 09:18 PM -
header help
By bag in forum External EngineReplies: 0Last Post: 02-26-2006, 10:43 PM -
Header Help
By ss~zoso~ss in forum External EngineReplies: 5Last Post: 02-24-2006, 03:40 PM
