    Nik
    elmira, new york
    2001 corvette
    Replacing clutch in my c5!
    okay I am a mechanic and Im very mechanically inclined and should have no problems doing it myself just wanted to ask for some tips from those of you who have done it. Im putting in an ls7 disc, and pressure plate, along with a fidanza alum flywheel arp bolts locktighted of course new through out bearing/cyl and new pilot bearing. also the drill mod that I have heard about on the line for better clutch engagement. which if you have a link for on how to do the drill mod that would be great! anyway... or a step by step process of the whole clutch r&r would probably helpful. but I just want to know if there is any preventative maintenence like on the torque tube or anything before I dig into it! anyhelp would be great thanks for looking!-Nik
    11 second club cabel's Avatar
    Wisconsin
    98 Z-28
    Don't tilt the trans and engine down to far or you will crack the dash.
    Nik
    elmira, new york
    2001 corvette
    thanks! thats a new one that no one has told me on several forums yet.
    Senior Member Z06-Goose's Avatar
    Colorado
    Avus Silver
    2007 Audi RS4
    Here you go. Click on "Dope's Clutch How To Write Up"
    http://www.cajundude.com/c5techhome.htm
    2007 Audi RS 4
    Senior Member t-rock's Avatar
    pocola oklahoma
    2002 firehawk 94 Z28
    dope's good
    mo.
    99 camrao
    I dont thank the fidanza flywheel will work with the LS7 pressure plate The LS7 uses the LS2 corvette flywheel and its different from any outher LS GM flywheel.
  1. Replacing clutch packs?
    By Dove1b in forum Automatic Transmission
    Last Post: 01-04-2013, 05:00 AM
  2. replacing the clutch in the bird
    By blk00ls1 in forum Firebird / WS6
    Last Post: 04-01-2012, 06:35 PM
  3. replacing my clutch+flywheel, what else??
    By AaBryan in forum Manual Transmission
    Last Post: 07-24-2008, 05:01 AM
  4. replacing corvette clutch
    By NIKDSC5 in forum Corvette
    Last Post: 05-13-2007, 08:17 AM
  5. replacing clutch??
    By FastAssZ in forum Drivetrain
    Last Post: 04-10-2006, 05:24 PM
