Results 1 to 20 of 21
Thread: Fix my WOT ping/knock!
05-26-2008, 02:31 PM #1
- Jun 2006
- USA
- 2001 WS6, 2003 SRT4(sold)
I need some suggestions on what to do. At WOT between 5k RPM-redline my 2001 WS6 M6 has a snapping/clicking sounding knock coming from the driver's side engine. It does it more when temperatures are warm. I only use Shell V-Power 93 Octane fuel or Exxon Mobile 93 Octane fuel.
In an effort to fix it I have done the following, in this order:
-Put 1 large bottle of GM Fuel Treatment Plus through tank
-Flushed coolant system and replaced with 50/50 dexcool (manual suggests)
-1 bottle of seafoam through gas tank
-Seafoam through break booster line
-Seafoam Deep Creep into intake manifold
-Replaced spark plugs and wires (at same time)
-Had car dyno tuned on a mustang dyno for 93 Octane fuel
The knocking/pinging is unchanged through all of this. It makes me wonder if it's actually ping or knock.
Other bits of information about my car:
Kooks LT Headers
Kooks high-flow Cats
Magnaflow 3.5" catback
SLP Lid
Bo White Ported and Polished Throttle Body
Spohn SFCs and LCAs
Hurst Billet Plus STS
05-26-2008, 05:27 PM #2
is the car tuned? Have you logged it to verify it's knock and not something else like an exhaust leak?
05-26-2008, 06:46 PM #3
- Jun 2006
- USA
It was tuned on a mustang dyno by a fbody shop. I've not tried to log anything yet.. I have a buddy with a laptop who may be able to assist with that next week. So I guess I haven't verified it is knock.
I couldn't imagine where an exhaust leak would be coming from since this sound is persistent through completely upgrading the exhaust components. Anything that could be leaking has been replaced as of last week.
05-26-2008, 06:52 PM #4
- Dec 2005
- Huntington Beach, California
navy blue metallic- 2001 trans am
does it happen when you blip the throttle? Run fine cold in the morning?
05-26-2008, 07:11 PM #5
- Jun 2006
- USA
Does not happen when throttle is blipped or if I give it a complete rev to 6k. The knock/ping only happens under load at WOT.
Does not happen when cold. Or at least I don't think it does - I only go WOT once the car is at operating temperature. I notice the knock/ping the most as temperatures rise outside but it could just be in my head.
The knock/ping doesn't happen every time I drive, but if it does it once, it will keep happening the rest of the time I am driving.
05-26-2008, 11:05 PM #6
- Feb 2007
- Punta Gorda FL
Black- 02 TA WS6
My 02 WS6 A4 does the same thing-sounds like a spark knock (pre-detonation)/ping to me...and I also use Shell. Wonder if it could be the gas? Never noticed if it does it more when its hot out, but it did it the other day, and outside temp was about 90.
05-27-2008, 03:39 AM #7
- Oct 2005
- Austin, TX
Black- 2001 Trans Am WS6
Do you have a K&N filter or some kind of oiled filter? My car did the same thing, then I yanked out the K&N because it was putting its oil through my MAF and into the combustion cycle causing knock. When I replaced it with a paper air filter and cleaned the MAF, knock went away.
05-27-2008, 09:57 AM #8
- Jun 2006
- USA
Paper filter. I may replace it anyway, and clean my MAF
05-27-2008, 10:10 AM #9
if you can get it logged and see how much knock your getting and what kind of timing your seeing that'll help. A wideband would also be nice so you can look at your fueling and see what's going on there. Might just be a little lean or have a little to much timing. The warmer it gets outside the more apt it'll be to knock so it's not just you, it could actually be knocking more as the temps rise. What was the temps like when it was dyno tuned?
05-27-2008, 10:53 AM #10
- Jun 2006
- USA
Temps on the day it was dyno tuned and test driven afterwards was probably mid-60s at time of the tune.. low of the day was 45F, high was 70F, average 60F. I can't say at what temp it was tuned.. likely pushing closer to 70F.
Yesterday it went as high at 85F.
edit: I really appreciate you giving a sincere stab at helping me!
05-27-2008, 10:55 AM #11
- Nov 1999
- over here...
so you only get the taping under load? (when the entire drive line is moving)
05-27-2008, 10:56 AM #12
- Jun 2006
- USA
Only under load.
05-27-2008, 11:00 AM #13
05-29-2008, 01:54 PM #14
- Jun 2006
- USA
If that's the case I wonder what it could be.
I have plans to datalog the car on Sunday. In preparation I replaced the air and fuel filters today; I believe the original fuel filter was still in there. It was an AC Delco. No change to the "ping" though the car feels a tad smoother, likely attributable to the fresh air filter. I will be cleaning the MAF and resetting the PCM at some point before the data log.
05-29-2008, 03:14 PM #15
I wouldn't reset it. You're not wanting perfect trims and all that. You're wanting to see what the cars doing right now. I'd leave it alone, it'll keep the log realistic.
05-29-2008, 03:15 PM #16
- Jun 2006
- USA
Okay. I will hold off.
05-30-2008, 11:48 AM #17
I had the same problem and it turned out the be the knock sensor believe or not. I thinkg gtotabob is on to something. Took a Saturday afternoon and replaced both of them sinceI had everything opened. I'll admit that I ran 89 Octane only a handful of times but believe this was the culprit, I definatly learned my lesson and wont EVER put 89 again!
05-30-2008, 12:05 PM #18
- Jun 2006
- USA
Hopefully that's not the issue - then again I guess taking off the intake manifold isn't very tough. It'd give me an excuse to do the LS6 PCV valve upgrade.
07-03-2008, 01:15 PM #19
- Mar 2006
- CHESTER, VA
BLACK- 2001 WS6
Same deal here. Knocking/pinging only at WOT, btwn 4500 and redline. worse when outside temp is warmer (horrible if >85deg F). New plugs,wires,fuel filter,air filterSeafoam through fuel and brake booster line. Only run Amoco 93oct. Cats replaced by dealer after Pontiac's pseudo-recall. Replaced SLP MAF with stock MAF. Cant figure this damn thing out, but cant race any ricers cuz I sound like crap! WTF? I don't have autotap or anything to tell me whats happening while driving. Where do I go next?
07-03-2008, 09:32 PM #20
- Dec 2005
Try deleting the !Air system if it isnt. Mine was doing that until I got a header job and Air delete
knock knock...who's there? wait...engine knock...
By jiveass in forum Internal EngineReplies: 60Last Post: 04-26-2011, 07:04 AM -
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 06:26 AM -
Ping maybe knock?
By jetaws6 in forum Internal EngineReplies: 12Last Post: 09-27-2010, 04:39 AM -
Engine Ping
By Retired Cop in forum Internal EngineReplies: 60Last Post: 01-29-2010, 04:47 PM -
Engine Knock Ping Might be trouble
By dr_ws6_00 in forum Internal EngineReplies: 5Last Post: 09-15-2007, 04:09 PM
