07-30-2007, 11:47 AM #1
- Nov 2005
- Huntsville AL
Bright Green Metallic- 1998 Z28 Camaro
Dropped Socket in Bell Housing!! Can I Drive?
Was unsuccessfully bleeding my clutch hydaulics and dropped a socket in the bell housing. Is it going to jam between the flywheel and the housing? I may need to go in to replace the slave anyway, but I'd like to drive it to a shop. Tow it, or drive it?
Jim 98 Z28 BGM
07-30-2007, 01:04 PM #2
I know I wouldn't take the chance. Id tow it.
07-30-2007, 01:56 PM #3
- Apr 2007
- San Diego
Red- 2002 T/A
Have you tried removing the inspection cover? Maybe with a magnet and a little luck you can get it out.
07-30-2007, 02:50 PM #4
07-30-2007, 04:24 PM #5
freind did the same on a new motor and blew it 2 days later soo yea dont drive
07-31-2007, 08:20 AM #6
When in doubt, tow it out... That sounds like a reaaaally bad day in the making, i would not drive it..
07-31-2007, 08:07 PM #7
- Nov 2005
- Huntsville AL
Ah didn't know about an inspection cover. Looked in the manual and didn't see it. Is it obvious where it is?
Jim 98Z28 BGM
08-01-2007, 04:15 PM #8
- Jun 2007
- corona ca
white, white and pewter- Rip99SSA4,74Z28M4,02SSM6
yeagh crawl under the car it should be directly in the center on the bottom of the bell housing
08-01-2007, 05:30 PM #9
its a smooth little cover maybe and inch or 2 across, use a pocket screwdriver to pop it out
08-04-2007, 09:53 AM #10
- Nov 2005
- Huntsville AL
Guys I looked and looked. Only possibility I saw for the Flywheel Housing Cover was a plastic cover around the starter. I took off the only small bolt but it didn't come off although it was loose. I pried it up and looked under and I didn't see into the bell housing so I don't think this is it. At the bottom of the housing there is no cover.
The manual talks about an inspection cover but never shows where it is.
Anybody actually take this thing off?
Thanks,
Jim
08-04-2007, 07:46 PM #11
Pull the starter completely off and that panel will come out. The inspection "cover" is a shiny aluminum circle at the bottom of the bellhousing. It's about 2" across. There's also another plastic panel on the other side. I would first just try the inspection cover since it's so easy to get off. Just pry it off and get a telescoping pen magnet and run it back into the bellhousing and maybe you'll get ahold of the socket. Might not hurt to do it on a Sunday directly after praying extra hard in church.
08-05-2007, 08:03 PM #12
- May 2007
- Fredericksburg, VA
Black- 2001 T/A M6
Or just take the bellhousing off and let the socket fall out
T-56/LS1 Bell housing
By AaBryan in forum Parts Wanted / TradeReplies: 0Last Post: 08-18-2008, 04:48 AM -
WTB: T-56 Bell housing for LS1
By tilly in forum Parts Wanted / TradeReplies: 2Last Post: 12-21-2007, 05:00 PM -
Dropped Socket in Bell Housing!! Can I drive?
By eldrijt in forum Manual TransmissionReplies: 5Last Post: 08-08-2007, 08:02 AM -
Bell Housing for 01-02 T56
By JD_Z28 in forum Parts Wanted / TradeReplies: 1Last Post: 07-19-2006, 07:46 PM -
Bell housing for T-56
By JD_Z28 in forum Parts Wanted / TradeReplies: 0Last Post: 03-14-2006, 03:23 PM
