Thread: Corvette wiper problem
04-30-2014, 01:24 PM #1
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
Good friend just picked up a 2000 Vette yesterday, found it down Carlisle this past week end. Black, 56,000mi six speed.
Anyhow it was raining when he picked it up and drove home after arriving home he turned off the wipers and he said they stop half way down.
They work correct and return to bottom on delay, low, high but when he shuts off the switch the go to the left stop point and then back about 1/2 way and Stop. Any help on why this is happening!99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
05-01-2014, 10:23 AM #2
- Jan 2009
- North Jersey
I'm thinking the motor is on its way out, something in the wiper transmission is worn or if the motor was replaced, the transmission wasn't reinstalled correctly.
05-01-2014, 05:28 PM #3
- Apr 2011
- Johnstown,PA
I got a chance just for a few minute's to look at them, really weird they seem to work just fine on all speeds until you shut them off and they go to the center and stop! Would the transmission cause this? someone was in there doing something cause the plastic cowl right above them is all busted like some moron who don't have a clue was in there.
05-04-2014, 09:30 AM #4
- Jan 2009
- North Jersey
I'm thinking the motor was replaced but the transmission wasn't set correctly. Remember, the wiper motor spins 360 and not back and forth. Might have to disconnect the wiper transmission, run the wiper motor, shut it off and reinstall the transmission with the wiper arms flat on the cowl. Only thing is, the wipers could swing down TOO low. It will take a few attempts before you have everything set correctly. You could also pull the wiper arms off and reset those. Keep us posted.
05-04-2014, 02:21 PM #5
- Apr 2011
- Johnstown,PA
I will thanks
wiper problem! help?!
By ls1formula in forum General HelpReplies: 3Last Post: 07-18-2009, 02:44 PM -
Wiper problem
By One_Bad_TA in forum General HelpReplies: 9Last Post: 07-14-2009, 03:06 PM -
98 camaro wiper problem
By coothies in forum General HelpReplies: 7Last Post: 01-31-2009, 03:49 AM -
Wiper problem
By speedracer25f in forum General HelpReplies: 5Last Post: 05-20-2008, 10:33 AM -
Windshield Wiper Problem...
By The_Wretched in forum General HelpReplies: 3Last Post: 01-16-2008, 09:22 AM
