Results 1 to 20 of 42
Thread: Billet Fuel Door install ques
06-09-2008, 06:51 PM #1
- Nov 2005
- San Antonio Tejas
black- 1998 Camaro SS
Anyone done the mitsubishi Fuel door replacement lately? I just got mine had it painted and I am planning on installing..but would like to get some more detailed instruction on just how it attaches....I read a thread from a long time ago but it really lacked a lot of detail..any help would be appreciated. Thanks.
06-09-2008, 10:03 PM #2
06-09-2008, 11:41 PM #3
- Oct 2007
- Beaver Dam KY
I think It is just a lot of drilling out the rivets and bolting them in. I always thought it looked good and would look damn fine painted black.
06-15-2008, 08:24 PM #4
- Sep 2006
- Jacksonville, FL
Sebring Silver Metallic- 1995 Pontiac Firebird
Saved these instructions a while back. They're not mine, and I would give credit to the person who made them, but I can't remember where I came across it.
Its fairly straight forward
You'll need some washers that are ~1/4 - 3/8 in OD...and that fit the bolts that came with the new fuel door.... you'll use them to sandwich your new door and the car body together....
You'll find it easier too if you remove your rear tire and wheel and loosen up the black body panel inside your wheel well...it just has some plastic screw keepers
1. Open your fuel stock door...you'll see some pop rivets that circle your door...get a drill that’s just barely larger than the size of the center of the pop rivers... and drill them out..
2. Pull the door off
3. If your going to re-use your plastic overfill catch thingie you’ll have to mod it by notching it where the screws on the new fuel door will pass thru it and notch it or drill out holes for them to pass thru... if your not going to re-use then proceed on to step 4.
4. Press the new fuel door against the outside of the cars body…. and at the same time place the bolts that came with the fuel door thru the holes on the fuel door...and thru or around the catch cup if you used it… they will not need to go thru the body of your car. in fact I don’t think they even come close..
Anyway...use the nut and washer to "sandwich" the body of the car between the washers and the fuel door. Don’t over tighten so that you can make minor adjustments for fit as you go.
5. Do the same for all bolts on the cover put everything back.. then check the fit and tighten everything down
6. Have a beer...your done
This took me about 35 minutes..its very straight forward....If you do a neat job at drilling out the stock fuel door you can very easily roll-back your mod to stock...
06-15-2008, 08:41 PM #5
Does anyone have any pics of this?
06-15-2008, 09:11 PM #6
- Oct 2007
- Beaver Dam KY
I do.. give me a sec and Ill edit this.
EDIT
06-15-2008, 10:41 PM #7
I was going to do this to my car when i first bought it,but didnt flow with my color.
06-15-2008, 10:46 PM #8
- Oct 2007
- Beaver Dam KY
Powdercoat that bastard SOM
06-16-2008, 05:45 AM #9
thanks buytdo you also have a pic from farther back to see the whole car with it
06-16-2008, 07:30 AM #10
- Nov 2005
- San Antonio Tejas
Billet Fuel Door
Thanks everyone! Got it installed was not as difficult as I thought..in fact I did not even have to jack car up or take off rear wheel just reached thru open fuel door to attach washers..tightened..ready to roll!
I will post pics...I had mine painted black, same color as my car...left the hex headed screws billet....looks real good!
Tron
06-16-2008, 09:03 PM #11
would this work on a 3rd gen (1987 iroc) and how much would this cost?
06-17-2008, 09:48 AM #12
I think the fuel doors are about $80 but I don't think it would fit the curves (or lack there of) on the 3rd gen.
06-19-2008, 07:15 AM #13
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
NICE! Can we have some pics zoomed out so the whole side is visible? Maybe something I would look into doing. Mine is white so even keeping it in the original finish wouldn't be too bad.
06-20-2008, 12:04 PM #14
Here you all go:
1998 WS7 T/A M6| SLP:Lid,Line Lock,LM Exhaust w/ORY,Skip Shift| Pacesetter LT| 80mm BBK TB| Centerforce LS6 Clutch| Eaton Detroit TrueTrac Differential| MAC Diff.Carrier Girdle| 3:73 Gears| Spohn Cntrl Arms| Hotchkis Adj PHB| H&R Lowering Sp.Springs| NX 150 Shot Direct Port|More Mods... FQuick Page
06-23-2008, 05:35 PM #15
did you do the ls1 front clip on that ta? just wondering if its the same one as the one in your sig.
06-23-2008, 05:43 PM #16
No thats not my car....just posted up a pic from the guy who owns this car's website! People wanted to see a pic of the Fuel door zoomed out...well, I posted a pic!
06-23-2008, 08:42 PM #17
06-23-2008, 09:10 PM #18
- Thornton, CO
We don't own imports....
06-23-2008, 09:13 PM #19
07-20-2008, 11:00 AM #20
- Sep 2007
- I sleep in the house...Live in the shop
midnight Blue- '99 Trans Am ws7
Yeah I just seen a civic with the same blue lights last night at walmart....looked SHHEEWWWT
Question: Billet Aluminum Fuel Door
By KITT#42 in forum Firebird / WS6Replies: 0Last Post: 02-20-2010, 07:16 PM -
Help: I need a part # for the Billet Fuel Door
By 1 TRANS AM in forum Appearance SectionReplies: 7Last Post: 07-31-2008, 08:55 AM -
billet fuel door?
By SSclint01 in forum Appearance SectionReplies: 25Last Post: 12-04-2007, 10:56 PM -
Billet alloy fuel door info.
By wicked illusions in forum Appearance SectionReplies: 2Last Post: 09-11-2005, 01:07 AM -
Can any body tell me how to install a billet fuel door?
By wicked illusions in forum Western MembersReplies: 4Last Post: 09-05-2005, 07:25 AM
