Results 1 to 20 of 42
06-09-2014, 10:09 AM #1
- Mar 2014
- vallejo
black- 1998 ws6 trans am
mpg what's average in city I only get 10 miles per gallon!!!
I have a 1998 ws6 and I only get 10 miles per gallon in city and maybe around 20 in highway was wondering if that's normal..I have a few bolt on..long tube header, slp lid, frost tune..just changed the spark plug but haven't tried to see of mpg inproved
06-09-2014, 10:32 AM #2
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
is it an automatic or manual...? either way that seems a little low. I can get 26-28 doing 70-85mph on the interstate but mine is a 6speed.
06-09-2014, 12:05 PM #3
- Mar 2014
- vallejo
It's a six speed
06-09-2014, 12:12 PM #4
you have an issue somewhere....mpg's should be a lot better than that. How old are the O2's? Do your exhaust tips have a lot of soot?
06-09-2014, 12:16 PM #5
- May 2013
- Nashville, TN
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
06-09-2014, 02:35 PM #6
- Mar 2014
- vallejo
It's a six speed
06-09-2014, 02:38 PM #7
- Mar 2014
- vallejo
Yea I just recently put on sensors and new cats because I didn't have none and you know how laws are in cali..yes I cleaned mass airflow last month
06-10-2014, 01:13 AM #8
how long have you had the car and has the mpg's always been that bad? You say you put cats on it....any chance it has mods you're not aware of?
06-10-2014, 08:32 AM #9
- Mar 2014
- vallejo
Might have other mods on it only had the car for about a year and gas mileage has always been this bad..mods that I think has is an ls6 intake, long tube headers, maybe cam and fuel injects 35 lbs not to sure I'm kinda new to all this
06-10-2014, 09:38 AM #10
Might want to data log it, if you had mods on it like a cam or heads may not have been tuned properly....Some ppl will pull their mods and not retune it when they go to sell.
Also 35lb injectors are not stock.
Just throwing spitball ideas out...Last edited by SMWS6TA; 06-10-2014 at 11:38 AM.
06-10-2014, 10:51 AM #11
- May 2013
- Nashville, TN
what kind of air filter do you have...? has it been replaced recently? sounds to me like the computer is changing the fuel ratio for some reason...seen vacuum leaks cause issues like this.
06-10-2014, 11:16 AM #12
06-10-2014, 05:10 PM #13
- Mar 2014
- vallejo
Has a k and n airfilter..has no vacune leaks check all of the car..the guy at tune by frost told me my computer had a tune already so he said it would be better to leave that tune because u wasn't sure what my car mods were but he did say there was some iregularity and the Rev limiter was set at 7k
06-10-2014, 05:11 PM #14
- Mar 2014
- vallejo
35 lbs injected are not stock? I didn't know would that cause the car to waste more gas, the car run great has a lot of power the only problem is that mpg is real bad
06-10-2014, 05:38 PM #15
right.....35's aren't stock. Stock is 28's. That leads me to believe you either have or had a cam or something....perhaps it was forced induction that they took off. Tough to tell. I would definitely say that's the root of your mpg issue though.
06-10-2014, 09:41 PM #16
- Apr 2010
- Alabama
Surprised no one has asked this but what are your driving habits? Do you floor it or have heavy foot syndrome?
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
06-10-2014, 11:59 PM #17
06-11-2014, 12:16 AM #18
I stomp the gas through 2nd gear, and into 3rd at least twice a day, and I pull away from almost every red light with great enthusiasm. I realize about 23 mpg combined city/highway, or, about 320 miles before I turn in for gas (usually around 13 gallons to reach a full tank).
Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
06-11-2014, 04:58 AM #19
- Apr 2010
- Alabama
10mpg would be hard to hit even with heavy foot syndrome and since he's concerned about mpg's I assume he's not flooring it everywhere he goes. He has a frankencar.....there are mods on there he doesn't know about or a tune for mods he no longer has.
06-11-2014, 05:10 AM #20
98's have a 14 gal steel tank. Smaller than the later yrs. The 35 lb injectors with mild bolt ons would be where I'd start. To answer your question = yes having higher injectors with a different program tune can effect the engine greatly. The injectors are an electronic control part. If the ecm tells applies currect, the amount of fuel dropped varies from 28lb vs 35 lb. More fuel will be dumped. Now if you add too much fuel yourplugs willfoul out. Pull a couple and look at them. Are they white or black? Smell like gas? Black & smell like gas, they could even be wet are all indicators of fuel rich. Your Ecm & O2's can only compensate so much.
00 FB Vert - Stock
$5.00 a gallon
By Sarge in forum Almost Anything GoesReplies: 19Last Post: 02-02-2009, 03:52 AM -
High Miles Per Gallon- G8
By matthewaqui in forum Domestics and ForeignsReplies: 0Last Post: 08-04-2008, 09:00 AM -
Gas Could be....less $1.50 a gallon?!?!?!?!?!?
By FORD RECOVERY EXPERT in forum Almost Anything GoesReplies: 6Last Post: 07-06-2008, 04:57 PM -
Yeah so.....gas is $3.19 a gallon here.
By nitrox28 in forum Almost Anything GoesReplies: 31Last Post: 05-18-2007, 04:51 PM -
WTF!!!! 4.50 a gallon here!!1
By Zboner in forum Almost Anything GoesReplies: 48Last Post: 08-11-2006, 01:44 PM
