Results 1 to 15 of 15
Thread: What kind of drive shaft?
01-29-2007, 03:35 PM #1
I read somewhere that 98-02 6 speeds come stock with an aluminum driveshaft but when i was puttin on my headers and y pipe, i noticed mine was steel. Think it has been changed or is what i read wrong? Thanks all.
01-29-2007, 03:49 PM #2
- Jul 2005
- Jacksonville, FL
Seen posts about this before on the early LS1 cars. Supposedly M6 and 3.23 A4 cars came with the alum, not always the case. Could've been changed though.
01-29-2007, 06:04 PM #3
01-30-2007, 07:03 PM #4
Whats the advantage of the aluminum? I know its lighter so the rotating mass is less.. but is it really that big of an upgrade going from the steel to the alum? If can get a used one for decent $ would it be worth it?
01-31-2007, 12:51 PM #5
aluminum is lighter, but isn't it more prone to breaking than steel would be?
01-31-2007, 02:34 PM #6
i would assume so
01-31-2007, 02:59 PM #7
- Nov 2006
- Broken Arrow, OK
Yes, the aluminum is lighter. Thats the big advantage to it. Also, I would much rather a driveshaft break than the 10 bolt
01-31-2007, 05:07 PM #8
- Jul 2005
- Jacksonville, FL
01-31-2007, 05:18 PM #9
02-03-2007, 10:02 AM #10
02-03-2007, 06:00 PM #11
02-03-2007, 06:27 PM #12
I have an auto, and bought the car off an older female schoolteacher who didn't do anything to it besides an airfilter.
02-03-2007, 06:38 PM #13
02-03-2007, 06:53 PM #14
excellent.
all I've done to it to make it faster is a Flowmaster Cat Back exhaust, lid, air bellows, and a throttle body bypass. how much power can the aluminum driveshaft handle do you think? I heard the 10-bolts can break at any amount of power depending on how you drive the car.
02-03-2007, 09:00 PM #15
- Nov 2006
- Broken Arrow, OK
The 10 bolts are very weak and will break on a stock power levels. Thats more probable on manual transmission cars than auto trannies though. You put a good set of sticky tires on a manual transmission car and you can bust the 10 bolt fairly easy. Same scenario with an auto tranny and its not nearly as likely to break the 10 bolt though. You probably won't need to worry about breaking your rearend anytime soon if that is what you are wondering
Drive Shaft
By transamgreen in forum DrivetrainReplies: 8Last Post: 09-25-2016, 05:45 AM -
Help: drive shaft
By sjohnson904 in forum DrivetrainReplies: 0Last Post: 05-20-2013, 09:19 AM -
drive shaft fit
By mikey gavin in forum DrivetrainReplies: 0Last Post: 05-10-2011, 11:40 AM -
Drive shaft
By andyramsaran in forum GTOReplies: 4Last Post: 04-02-2010, 08:01 PM -
Drive Shaft not going in!!!!!!
By nmmccasland in forum Manual TransmissionReplies: 3Last Post: 06-11-2008, 11:24 AM
