    Junior Member burnsxxxls1's Avatar
    Apr 2010
    bremen
    2004 gto
    v6 swap......HELP PLZZZZZZZZ
    i just picked up a 1996 camaro rs i want to put a lt1 or ls1 wich ever is easier to put in it .... so my question what engine what kind of car or truck to pull one out of wat all will i need fule pump water pump etc. and is there any wright ups on this like some decent instructions it is a manual will i haft to switch trans ... should i pull the engine from the top or bottom plz help
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    It's easier to buy a V8 car than try an convert a V6 car. This is due the differences in the wiring harness, PCM and various suspension components.
    If you're dead set on doing this then you'd be best off buying a salvaged (or other suitable) V8 car and swapping things as needed.
    I see "Bremen" as a location. Are you located in Germany?
    67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
    Carbon footprint? CLOWN SHOE!
    Junior Member 1999sscamaro's Avatar
    Jul 2010
    st louis mo
    1999 ss camaro
    Quote Originally Posted by burnsxxxls1 View Post
    Its crazy what you have to do to convert a v6 to a v8. i would personally go with the ls1 its more efficient and there are alot more performance parts out there for them. it does make more sense just to buy a v8. if you are dead set on doing this with about 7000$ you need the engine i would go to a salvage yard find one with transmission Manuel or auto what ever you prefer. i used to work for a salvage yard, one like that will cost you around 3000 for about 110,000 on the engine.then you need the wiring harness thats about 1500$ then you need new supseion to compensate for the extra weight, new radiator, probably new calipers and brake roaters,new fuel pump,if you want new gauges for a ss or z28.thats just of the top of my mind it will cost alot of money but it can be done. if you do,do it go threw the bottom of the car.
    Apr 2010
    bremen
    2004 gto
    nah i live in the united states ..... never new it was so complicated be cheaper to just buy a v8 car then
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Georgia?
    FWIW, old school cars are a piece of cake to swap engines. Even 3rd gens it's fairly straight forward. It's the OBDI and OBDII cars where it became a PITA to do. Mind you it can be done but it's a lot more involved.
    And if you're gonna do a 4th gen do an LS1. Greater availability of parts and much easier to tune (computer wise). If you can afford it do an 01 or 02 as they are the best of them all (parts wise - no EGR and LS6 intake, best factory exhaust, etc).
    And if you do an LT1 car do a 96 or 97 as they are OBDII.
  1. Trans swap for swap
    By [CJ] in forum Drivetrain
    Last Post: 08-12-2011, 12:11 PM
  2. Engine swap and computer swap
    By mrmiatanut in forum Computer & Tuning
    Last Post: 09-08-2007, 05:10 PM
  3. To Swap, or not to swap, that is the question.
    By HasselZ28 in forum Camaro / SS
    Last Post: 08-11-2007, 07:58 AM
  4. Replies: 6
    Last Post: 01-30-2006, 01:02 PM
