    Regina, SK
    2002 Camaro B4C
    musty smell from A/c
    2002 Camaro, when first starting car or turning A/C on musty smell for about a minute or so, after that not noticed. Would some dain hose be plugged and water lying somewhere in the system causing it. Anyone with simuliar problem or ideas?
    Old Enough to Know Better Crimson Sin's Avatar
    Feb 2006
    Seattle..Land of Constant Rain..
    Red Fire
    2007 Mustang GT/CS
    Quote Originally Posted by badbrad View Post
    I get this question all the time at work. ( I run a Goodyear Service shop). There is a drain pan under your A/C Evaporator ( dash unit ) that catches the condesation from your A/C & Heater core. Bacteria will build up on/in this tray, especially if one of the drain passages gets a little plugged. Short of pulling the dash or physically cleaning the catch tray. There is a chemical we use at work to *clean* the tray. It will kill the bacteria and get rid of the odor fairly cheap and quickly. Most NAPA's etc will have it. I forget the name, it's usually in the TEMP product line at NAPA. There's an air freshener that you can use to, comes in an aerosol can. Ozium or something VERY close to that ( sound of the name ). Turn the car on, Turn the A/C to Max and shut the car off. Then spray into all the vents (ALOT). I recommend having the windows down as well and not breathing more of this crap than you have too. LET IT SIT. Couple hours. Repeat Next day if odor persists. It will go away in a couple treatments. Or.. Yank the drain tray, clean it GOOD. Find the stopped drain ( usually a few pine needles worked their way in and clogged the little run-out passages, or something similar ). I sell this service at work for (depending on the car ) 200-500 dollars. Got 1200 once from an E500 Mercedes owner. Go figure. LoL but it was 9.6 HOURS to R&R that dash.
    Do Not Anger the Horsepower Gods ! MOD !!
    2007 Mustang GT/CS
    2001 SS Cammed. Stalled. Geared. Tuned...Gone but not forgotten..
    pornhub.com has a tribute thing for MJ at the top of page. I can't even jerk off without being bombarded by the bastard.
    Senior Member camarojunky74's Avatar
    corona ca
    white, white and pewter
    Rip99SSA4,74Z28M4,02SSM6
    right behind the glove box is the heater core and a/c area, pull the cover off and do what this guy said, some simple green and a small brush will do the trick as well, basically its clogged like you thought it was
    Motor City MI
    99 Trans Am
    Quote Originally Posted by camarojunky74 View Post
    As air comes into the cabin from outside the car, which does it hit first - the AC evaporator or the heater core? I'm wondering which I should try to clean first... seems like the upstream item will have more dirt/fuzz etc needing cleaned off....
    Motor City MI
    99 Trans Am
    I did some more research and it's clear, the incoming air goes thru the evaporator first, then the heater core if the hot/cold door is set to allow air thru it. Guess that makes sense - should have known
    USA
    Velocity Yellow
    2008 Corvette Z06
    Just a heads up...
    This thread is over 2 years old. And the OP hasn't logged on in 2 years either.
    2018 Tahoe - Silver - OEM
    Pittsburgh
    2008 Hummer H3
    Wink
    Just a heads up...
    New guy Brah.
    USA
    Velocity Yellow
    2008 Corvette Z06
    New guy Brah.
    Hence the reason I was informing him on the status of this thread!
    Pittsburgh
    2008 Hummer H3
    USA
    Velocity Yellow
    2008 Corvette Z06
    Well, I'm good because I learned something new. Again
    Vicksburg, MS
    2002 Camaro SS
    Almost all old cars have a musty, mold infected AC system.
    Here's some stuff that you can spray into the vents:
    http://www.air-conditioner-cleaners....rPurifier.html
  1. i smell gas
    By damianj03 in forum External Engine
    Last Post: 04-03-2010, 01:57 AM
  2. I smell gas
    By northslider in forum General Help
    Last Post: 01-28-2010, 04:18 PM
  3. gas smell !
    By tdeath in forum GTO
    Last Post: 06-25-2007, 07:12 AM
  4. gas smell
    By 94redmaro in forum General Help
    Last Post: 01-17-2007, 05:17 AM
  5. Car Smell !!!
    By Solidify in forum Firebird / WS6
    Last Post: 10-30-2006, 10:31 AM
