Results 1 to 20 of 26
Thread: 150 wet on stock engine
01-11-2006, 07:25 AM #1
- Oct 2005
- dodge city Ks
pewter- 2000 trans am ws6
I was wondering if there is any problem with me running a 150 NX wet kit on my trans am. It is pretty much stock except for longtube headers, ory, loudmouth, slp lid, and smooth bellow. All the internals are stock. Have all necessary hardware for the install just wonderin if engine, tranny etc. can handle it
01-11-2006, 08:19 AM #2
the engine and trans should deff. be able to take it, 150 is the highest shot that i've heard to be ok to run on a stock engine reliably. You are pushing it with the 150 wet, but it should handle it. Just my opinion, i know others will correct me if i am wrong
98' SS Convertible Camaro-76k-Build # 1471, Cragar SS rims, RK SFC's, MAC Panhard, LSX Tune, Shaner S3,
SLP:short thro,Strut tower brace,fan switch
MTI Power induction kit,40 Series muffler,Pacesetter LT's + ORY,12 CD changer,3800lbs
http://www.cardomain.com/ride/787506/1
01-11-2006, 08:35 AM #3
- Aug 1999
- Arizona
Originally Posted by ws6man
Just make sure you have enough fuel, run all the safety devices and don't run lean.Black 1999 Blown Convertible A4
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
01-11-2006, 03:34 PM #4
i run a 200 motor rated (135 rwhp) on stock motor and fuel system. over a year now.
01-12-2006, 03:37 AM #5
- Retired Outlaw Sum Bitch
I agree with all the above....only thing I would consider is a 1 range cooler spark plug....
01-12-2006, 04:03 AM #6
yeah i forgot to mention that. i run 2 steps colder plug. good catch. champion RC9YC
01-12-2006, 04:48 AM #7
- Dec 2005
- GARNER NC
SILVER- 1998
I would also recommend a fuel pump. I have seen a few cars lean out on a 150 wet. I would also recommend taking some timing out of it. I will be a safer way to run the 150shot. Just my .02
Ryan
01-12-2006, 06:57 AM #8
- Oct 2005
- dodge city Ks
Thanks
Ok, thanks guys, i have ngk tr6 plugs already and im have access to ls1 edit to turn up the fuel etc. I have my own cable on ls1 edit because I bought it from a guy I know, so tuning is no problem. My Nitrous will turn on at 3000RPM and turn off during shifts. Im a newbie on this site and this was my first post ever, so thanks for the help!
01-12-2006, 07:03 AM #9white1Guest
I believe the fuel pump issue is that the stock pump can't handle the demand for fuel. Thats why another fuel pump was recomended, at least thats why its recomended on the trucks.
01-12-2006, 03:21 PM #10
^^not enough fuel supplied for the demand=running lean.
01-12-2006, 03:23 PM #11
i am thinking about nitrous on my car, but i'm a pussy and would only run a 100 shot i think, as long as i get up over 400 i'm happy! do you think you can spray thru the shifts with a 100 shot?
01-12-2006, 03:28 PM #12
- Aug 1999
- Arizona
Remember its not HP that kills trannies. Its torque.
Some have gotten away with it. But plan on a rebuild.
01-12-2006, 04:05 PM #13
how do you program it to not spray on the shifts? is it similar to a window switch or what do you have to use?
01-12-2006, 04:36 PM #14
Originally Posted by NE98LS1
-somebody
01-12-2006, 04:51 PM #15
ok, i know how a window switch works, but when you are saying not spraying on the shifts, are you just talking about setting your window to below where your rpms fall on an upshift?
01-12-2006, 05:06 PM #16
- Aug 1999
- Arizona
You stop spraying just before you shift.
01-13-2006, 08:11 AM #17
manually? or is this done by a computer?
01-13-2006, 10:01 AM #18white1Guest
The window switch controls it. It fires the solenoids if Im not mistakes, it will fire them at lets say 3000 rpm then drop them out at 5800 or whatever your pills are set for so from 5800 till your shift point it wont be spraying, then when it shifts it will spray again.
(This is how I understand it at least someone correct me if Im wrong)
01-13-2006, 12:16 PM #19
- Aug 1999
- Arizona
Thats about right.
01-15-2006, 06:16 PM #20gogo4Guest
Hey about those msd window switches, the msd runs into a relay does the relay ground itself have to be provided? I am not sure if i am supposed to ground out the msd window switch and leave the ground out of the relay or ground both for it to work?
stock lt1 engine parts
By fastlt196 in forum Parts For Sale / TradeReplies: 0Last Post: 03-31-2009, 11:45 AM -
Stock LS1 Engine Parts F/S
By LS1Fever in forum Parts For Sale / TradeReplies: 109Last Post: 08-08-2007, 01:56 PM -
I Need Some Stock Engine Parts!!!!!!!!!!!!!!!!
By 98_BAT in forum Texas MembersReplies: 1Last Post: 07-27-2007, 04:42 PM -
Cam on a stock engine? Yes? no?
By Zapper2003 in forum Internal EngineReplies: 4Last Post: 04-18-2007, 05:37 PM -
PTK results on stock engine at 7 PSI boost
By Darren P in forum Forced InductionReplies: 3Last Post: 10-19-2005, 11:28 AM
