Results 1 to 10 of 10
Thread: abs inop?
    Senior Member 440 rwhp trans am's Avatar
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    abs inop?
    what dose this mean? how do i fix it???
    DFW
    '18 CTS-V
    '13 ZL1
    Quote Originally Posted by 440 rwhp trans am View Post
    means if you slam on your breaks they will lock up the wheels/tires and not anti-lock, like they should. check both the senor and fuse. also see if it's grounded out somewhere on the rear end/axles and/or that there is not break dust that's making the ABS inoperable...
    maryland
    98 z28
    Where you on a dyno or did you do a really long burn out? One time when my car was on the dyno it came up saying abs inop. I guess it sensed the rear tires moving and the front ones not. I just drove it a little and it went right off.
    Feb 2006
    Check the relays! My Z had that problem too!
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    Quote Originally Posted by zman98 View Post
    nope it comes on when i drive for a while.
    Funny. Mine is on all the time as well, but it stays on, even if i shut the car off. TCS OFF light is on all the time too, but the switch don't do jack. Good luck, personally i like the ABS off, but if the light flashes, according to the owners manual, you basically have no brakes, either the pedal will be super soft, or hard as a rock.
    tattoo artist,esquire sic2001's Avatar
    Huntington Beach, California
    navy blue metallic
    2001 trans am
    did you ever find out what this was? Im having the same issue
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    Quote Originally Posted by sic2001 View Post
    yes i did i had lowering shocks and normal springs. guy was a jack ass that put them in there!! when your suspention is fucked the light comes on try looking over your stuff and see if anything is worn out
    navy blue metallic
    2001 trans am
    I have Koni SA and lowering springs and all semi new stuff under there. I had a look and all looks good, even the bushings are still firm and clean.
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    i have no clue then. no one could figure mine out then i just took everything apart and bam found it
  1. abs inop...help
    By kc's01t/a in forum Suspension and Handling
    Last Post: 07-16-2009, 01:02 PM
  2. ABS Inop
    By levityinc3 in forum General Help
    Last Post: 05-01-2009, 08:37 AM
  3. ABS Inop
    By TRNick in forum General Help
    Last Post: 12-30-2008, 09:19 AM
  4. Abs\inop
    By 1972_Z-28 in forum General Help
    Last Post: 07-24-2008, 11:48 AM
  5. Abs Inop ?
    By redwhiteandnew in forum Firebird / WS6
    Last Post: 08-14-2007, 03:57 PM
