Results 1 to 20 of 28
    ls1ftw tigersport14's Avatar
    Tulsa
    98 trans am
    i need someones help
    so yesterday i was hot roding it pretty good, and then i started to hear a knocking noise comming from the motor, so i took it over to my friends house and checked the oil level, it was 2 quarts low, so today i took it up to get an oil change. and the guys there filled it up with full synthetic castrol, but the knocking still continued, they think its the lifter...does anyone know what might be the problem?
    Junior Member josh110781's Avatar
    harrison twp. MI.
    2000 trans am WS6
    same thing happened to me you starved your engine of oil. when that happened to mine it was a rod bearing. had to rebuild the engine
    slp lid,maf and smooth bellow. ls6 intake, cnc ported and polished ls6 heads with competition valve job. cam 237,242 .603,.609 113 lsa. pacesetter longtube headers and off road y-pipe. magnaflow catback
    dyno numbers on a mustang dyno
    394 rwhp @ 6300 RPM
    345.7 rwtq @ 4800 RPM
    Tulsa
    98 trans am
    =O wtf wtf wtf, so im basically screwed?
    Tulsa
    98 trans am
    can i still drive it?
    harrison twp. MI.
    2000 trans am WS6
    i could be wrong but mine was 2 quarts low when it started knocking and i wasnt hot rodding it at the time just out for a drive.
    Tulsa
    98 trans am
    so..is it still driveabel?
    harrison twp. MI.
    2000 trans am WS6
    i parked mine untill i could pull the engine out and check it out. i guess it depends how bad it is but sooner or later the engine will go
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    could be the valves but yea you starved your engine and chances are it is a rod bearing. listen and try to find where the knocking is coming from. Synth really wont help this type of knocking. also is it a ticking or a KNOCKING.
    Junior Member secretpyg's Avatar
    birmingham,alabama
    orange
    1996 trans am
    it is until you sling a piston through the block.the more you drive it the more damage you are going to do.right now you are beating a space as big as the piston is round and as deep as the rod bearing is thick into the head.i would at least drop the pan and replace the bad rod bearing until you can rebuild the bottom end of the motor.this will limp you a long for a bit but you are still taking a chance at blowing the motor.
    Shepherd, Michigan
    98' trans am
    harrison twp. MI.
    2000 trans am WS6
    yup i would just park it until you can get it fixed. i think i had 2 or 3 rod bearings that were all chewed up
    birmingham,alabama
    orange
    1996 trans am
    i agree that the best thing to do is park it
    Tulsa
    98 trans am
    its a knocking
    Shepherd, Michigan
    98' trans am
    park that sob
    Tulsa
    98 trans am
    so theres no way it could be the lifter?
    harrison twp. MI.
    2000 trans am WS6
    most likely not. a lifter is more of a tick verses a knock which is most likely a bearing
    Tulsa
    98 trans am
    how much will it run me to fix it
    harrison twp. MI.
    2000 trans am WS6
    depends on what you want to do to the engine. do you want to keep it stock or build it up. I chose to build mine up since i had it out of the car already.i spent upwards of $6000. if you keep everything stock shouldnt be much more than $2000
    Tulsa
    98 trans am
    is that doing it yourself?
    georgia
    1998 pontiac trans am
    $150 for a machine shop to inspect the heads plus the cost of any bent valve stems, which most likely you have bent some. about $70 for new rod and main bearings, a little more for oversized ones if crank can be turned. most likely you wore a grove in your crank. i found a crank on here for $125 i dont reccommend welding the crank if the bearing wore it beyond having it turned. i had mine welded and it broke on the throw that was welded a year later. if all you need is turning it will cost about $100 to $150 depending if any malory (i believe is what is called) needs to be added to balance your crank. also possible, you might have cracked a piston. i did. you basically are in need of a total rebuild. dont cut corners like i did. i could have ruined my block by cutting corners. do it right and be patient. i'll have about 3,000 in my rebuild when i'm done. that's my budget anyhow. good luck
  1. Someones at the door...BRB
    By BadBlueBird* in forum Member's Rides
    Last Post: 07-11-2011, 02:16 PM
  2. Help: I'll but someones Trans am/firebird dash&doorpanels
    By Eganslp in forum Appearance Section
    Last Post: 11-18-2010, 10:27 AM
  3. the dumbest ? someones asked about your car?
    By justinmc978 in forum Almost Anything Goes
    Last Post: 11-22-2009, 07:03 PM
  4. I need to borrow someones...
    By eddielb in forum Western Members
    Last Post: 12-04-2008, 12:50 AM
  5. need someones 2002 SS last 8 of vin
    By 1BADDLS1 in forum Camaro / SS
    Last Post: 03-02-2007, 04:55 PM
