Results 1 to 20 of 32
05-05-2007, 05:45 AM #1
- Oct 2005
- Fayetteville North Carolina
$2000 to spend, what should I do?
I have stock 00 SS M6. I also have a set of 4:10 gears still in the box that I have been holding on to for quite a while. My wife just gave me $2000 to spend on my car any way I wanted. I want to get the most bang for my buck so I am considering different options. I was thinking along the lines of the following: Install gears, purchase diablo tuner, install y pipe, headers, intake, throtle body, mass airflow and lid. (I may have to throw in a little extra cash to get it all done)
My friend says to forget the bolt ons and buy a good set of heads and store them until I can afford to buy everything else and pay for labor to install.
What would the rest of you do? I am looking for some ideas.
thanks! Rob
05-05-2007, 06:20 AM #2
I would say headers, y pipe and cat back, lid, and cam if u had enough left over, but thats just me, and thats what i did hehehe.
05-05-2007, 07:20 AM #3
- Jan 2006
- Shepherd, Michigan
your friend is wrong. get bolt ons first.
um your stock tb can handle up too 500 hp/tq so dont swap out..if anything get it port and polished. S3 are some good stock TBs. dont mess with the MAF either its fine. here is what you should get with 2k..a new strange 12 bolt rear or go install gears, headers, cat back system, ls6 intake, and SFC. no matter what you do. get a good pair of weld on SFC!!!!!!!!
05-05-2007, 06:52 PM #4
ur friend dont no wut hes talking about. You gotta get full bolt ons and get the engine breathing well before you do internal work. For $2k i wood do...
Exhaust
Headers/ Ypipe
Lid
P/P TB
LS6 intake
install those gears
UD Pulley
Subframes
You should definatley have $ left over, and can install most of if not all of those by urself
05-06-2007, 07:15 AM #5
- Jan 2006
watch out for the UD pulley. make sure they are harmonically dampened
05-06-2007, 10:35 AM #6
05-06-2007, 01:54 PM #7
what do you have done already? I recommend some SFC's for sure, Cat-back exhaust, lid, and then probably headers if you can.
05-06-2007, 03:41 PM #8
ls6 Intake, Long Tube's, Exhaust, Bigger Throttle Body, Cam!!
05-06-2007, 07:16 PM #9
05-07-2007, 09:47 AM #10
- Oct 2005
The car is all stock except the free ram air mod. I am torn between the bolt on stuff or go ahead and doing the patriot head/cam package. Speedinc has it for $1895 including head gaskets, and rocker arms. I can get it all installed from a local speed shop for around $650 (not including tuning). My thinking is that after the internals are done I can do the bolt ons a little at a time as I can afford it or find good deals on stuff. I am really torn on this though.
05-07-2007, 03:02 PM #11
- Jan 2006
get bolt ons first. trust me it will be better. then after you got all the bolt ons then you get heads and cam..that way all those bolt ons will help and compliment your h/c set up cam and heads cant run at their highest potential without being able to get all the air it needs and getting the spend fumes/air out as quickly as possible.
think of it this way..would you buy a gun with out first buying the bullets?
05-07-2007, 03:09 PM #12
- Nov 2006
- Broken Arrow, OK
Build from the back to the front and smallest to the biggest, always. If you make the car top heavy(lot of HP with no supporting mods) and a small foundation, it won't perform anyways.
Listen to what Shady has been trying to tell you, he knows what he is talking about from experience.
05-07-2007, 03:10 PM #13
05-07-2007, 03:27 PM #14
NX kit for sure
05-07-2007, 04:15 PM #15
- Oct 2005
why do I need to replace the oil pumb if I install a cam?
05-07-2007, 04:22 PM #16
- Jan 2006
i really dont know exactly why..but i know its strongly recommended and stock oil pumps seem to die after cam installs.
05-07-2007, 04:38 PM #17
- Oct 2005
So that is why speedinc sells oil pumps in the valve train section!
05-07-2007, 06:18 PM #18
TSP Cam kit 589.00
Headers 289.00
Custom true dual w/xpipe from local exhaust shop 295.00
SLP LID 86.00
free mods free
Install cam, headers,valve springs, pushrods 500.00
1 Day on the dyno at TSP w/ Jason tuning it $350 for 12 pulls.
End result 368rwhp/355rwtq
Total $2200
Keep in mind this was a small cam, stock heads, stock LS1 intake, stock internals, stock MAF, stock TB,stock everything except exhaust, lid, cam. This is a very street friendly car, also has great sound cam was cut on 112lsa
DO NOT screw with MAF if it is working fine. I know guys that has 650 rwhp cars and stock MAF. The reason I have a SLP is because I started screwing around with mine, that is also the reason it took 12 pulls on the dyno, my car baselined at 217rwhp with the messed up MAF, changed out the MAF after troubleshooting everything else 10 pulls later 368rwhp, so in my case a messed up MAF cost me 140+rwhp. Messing with the MAF is like toying with someone's Pacemaker, they start breathing hard, gasping for air, eventually falling to the ground.
05-07-2007, 06:51 PM #19
- Nov 2006
- Broken Arrow, OK
You don't HAVE to swap the oil pump when you do a cam install, but you might as well. Say you don't replace the pump and you get it all back together and then the pump goes bad 3,000 miles later. Then you you have to pull everything back apart to swap the pump. Its the same principle of putting new plugs in while you are doing a header install. You are already there so do it then instead of having to get in there a second time down the road.
05-07-2007, 07:09 PM #20
Headers and LS6 intake alone makes a huge difference. I just did mine and its night/day difference. I already had all free mods/lid/bellows/trueduals/and SLP 1.85's with Z06 valvesprings. The LS6 intake and headers produced more than all the others combined. Bolt-ons definately first though. If your stock exhaust and intake tract chokes a stock head/cam I'm sure the heads/cam combo will net you the least noticable gains until you free up the breathing a bit.
Question: 3k to spend on t/a
By reaper ws6 in forum General HelpReplies: 17Last Post: 01-06-2012, 01:26 PM -
$11K to spend......
By pinky93 in forum Forced InductionReplies: 44Last Post: 03-24-2008, 04:56 AM -
$2000 to spend what should i do?
By william SS in forum Camaro / SSReplies: 20Last Post: 06-27-2007, 08:12 PM -
if you had 6k to spend
By third_shift|studios in forum Almost Anything GoesReplies: 70Last Post: 05-21-2007, 06:50 PM -
Best way to spend a $1,000
By bguns10 in forum Firebird / WS6Replies: 7Last Post: 05-10-2006, 09:21 PM
