Thread: electronic to a non electronic?
02-14-2006, 11:46 AM #1
- Jan 2006
- Forest City, NC
Red- 1999 Camaro SS
I want to change my 4l60e to a non electronic tranny, any suggestions, I am gonna be running a 6.0 built with hopefully alot of HP and TQ. How hard is this and what all do I need?
02-14-2006, 02:35 PM #2
- Sep 2005
- wisconsin
you can change your 4l60e to a manual valve body, or use an adapter and go to a t350 or 400
02-18-2006, 09:04 AM #3
- Feb 2006
There is no advantage to changing to a non-elecrtonic, You should consider getting your E model remanufactued with hardened internals and a 10 inch converter
03-06-2006, 04:49 PM #4bomcdGuest
This is what I need to do...
I already have a very strong th350 in my 82 Trans Am.. I want to swap in the newly released LS346/440 carbureted LS2
Where and what adapter do I need to use this motor with a th350.
I want to keep the 350 primarily as I do not want to have to change my stock shifter and the stock center console to a post 82 overdrive model..
Thanks...!
03-07-2006, 06:23 AM #5
- Feb 2006
Check out Yank Racing to see who builds their tranmissions
03-08-2006, 11:10 AM #6
- Sep 2005
- wisconsin
Originally Posted by bomcd
here is the part # hup-hp3795 you can use your factory ls1 style flex plate if you grind out the bolt holes a little bit, this is what i didLast edited by jay_lt4; 03-08-2006 at 11:13 AM.
Electronic Cutouts - where and how many
By sunseteffler in forum External EngineReplies: 3Last Post: 05-31-2013, 04:06 PM -
For all you Electronic guys....
By SVG210 in forum General HelpReplies: 19Last Post: 07-24-2008, 01:31 PM -
Electronic Cut outs
By 98BlackTA in forum External EngineReplies: 9Last Post: 11-29-2007, 06:37 PM -
electronic
By 35thAnniZ28 in forum Almost Anything GoesReplies: 10Last Post: 11-19-2007, 03:35 PM -
Electronic cut outs
By Mjolnir in forum External EngineReplies: 20Last Post: 03-08-2007, 11:37 AM
